E6400 -> 2.4 300FSB?
smilepak
Just finish putting in the Thermaltake Big Typhoon, what do you guys think of the stat? A bit hot?
double check ur temps with "core temp beta". Otherwise it looks ok for an OC. Go further.
It looks like you only just started Priming.
What are load temps after 1/2hr or so of solid Prime?
I ran it all night and the temp remain the same. Prime is fine, so I think i will pump it up more.
What he said.
At a vcore of 1.3-1.4V you should be able to clock it over 3.0GHz without much problem.
Theli said:
What he said.
It looks like it so far. I am using Kingston Value Ram DDR2-533...
So far so good...
That may of course be a problem, depending on how high you will be able to clock the memory.
Yea, i think i hit the max @ 325FSB, once I get to 330, it locks up the mine I apply the clock speed. Rock solid @ 325, so I put it down to 320 right now. Which is running very nicely. It might go futher if I pump up the voltage. I might do that after I take off the HSF and recheck the seating on it and the AS5. The temp does look a bit high compared to other people here.
But so far, i am extremely happy with the duo...
