DVI dual-link with LCD
Majed
If i bought a high quality DVI Dual-Link cable to use it with my HP w2207 instead of the normal dvi cable, is it sure i will I get a better/sharper image or just keep the normal one?
thanks in advance.
Single link should be fine, it supports up to 1920x1080 at 60 Hz. Since DVI is a digital interface, you won't get a clearer picture by switching to dual-link.
Ranma13 and karatekid.
thanks 4 ur replay.
so it will be fine.
