dust resistant chassis
what is the best solution aginst the dust between this models :
Silverstone FT02B-W USB3.0
Corsair Obsidian 800D
Corsair Obsidian 650D
Lian Li PC A77FB
i'm searching a particular solution whit optimal ventilation and dust filter quality to keep out the dust better than the averange cases.
Probably Silverstone. 3x 18cm fans keep a nice positive pressure inside the case, pushing dust out from every hole instead of sucking it in. The fan filters are OK too.
Edit: I have Raven02 which has similar interior layout, and there's basically no dust inside after 7 months of usage.
My raven is just now starting to show dust on the power supply cables coming from behind the motherboard tray in the bottom right. It has been 18 months since I built the rig and its just now showing. The motherboard and everything else is completely clean still and I live in a pretty damn dusty environment, (South Dakota). Pics of the new build and dust after 18 months are in the case mod forum in the show your rig thread...
