Dumb question but ....
Yep, Compressed Air is a very general idea.
But ideally, you wanna hit the areas that dust bunnies favor: fans & heatsinks. They love migrating to those things and multiplying.
crazyhorsejohnny said:
What is the best way to clean inside your case? Using can of air?
That is all I ever use. Do not mess with an air compressor, as water builds up in the bottom and can shoot out of the nozzle and then fry your parts if you do not remove the water properly.
I use a Dyson Vacuum, no need for compressed air, it sucks like crazy!
I bought it knowing it would be ace for cleaning my PC.
Air compressors might be useable if you have a good water trap on the line, but then the cans of air are better anyway (who wants 90psi slamming into their PC, and if you don't why not just use the can?) because you can get the straw into smaller spaces than you can an air compressor nozzle.
