Dual card question
romeo11523
I just bought an 8800 gts 640mb without really looking at things, ooops! I need another card for my third monitor, would I be better to pair the gts with an 8800 gt or another gts?
Thanks,
Ryan
Well getting another 8800 just for a third monitor would be waste of money because if you did enable SLI, only one monitor would work.
What you should do is buy a cheap PCI gfx card just for the 3rd monitor.
if your trying to play games on all 3 monitors no it wouldn't because to display mulitple monitors off different cards you cannot have SLI on so you loose all speed bonus of having 2 cards.
If you only want 3 monitors for normal stuff but want to play game son just 1 screen then all you ahve to do is just enable SLI when you wish to game to get the speed bonus, and then turn it off when your not gaming.
I'm wondering if I was too quick to jump and buy the gts, I feel buyers remorse from paying $360 for it and not the $300 for the 8800gt. Why is the GTS more expensive?
Thanks,
Ryan
