Hi,
On a dual boot system, still testing the waters with Win7 so the configuration is as follows:
C: WinXP
D: Win7
Primary partition is C and its Boot folder was located in C.
The problem is that somehow the whole C:\Boot was deleted, I'm guessing a virus cleanup gone wrong. System Recovery was off.
Whenever I try to boot, the "An error occurred while attempting to read boot configuration" shows up and I can only restart.
I've used the Win7 DVD, which doesn't see the partition with Win7 already installed and attempts to install it from the beginning. I'm also unable to use the recovery console since it goes straight to Setup.
I've used the Hiren Boot CD with WinXP Mini and am able to access all data on hdd. I've tried to copy the contents from D:\Boot and Windows\Boot like the bootmgr to C:\Boot and I'm getting an extra option at startup to check memory but still it reboots continuously.
Does anyone know what kind of files should I copy in the Boot folder located on C: in order to have the full boot selection back at startup?
A lot of thanks, am pretty much out of ideas.
Josh
C: WinXP
D: Win7
Josh
