I think your router will have to have 4x4 MIMO antennas (for 4 total connections) and compatible equipment on the other side to achieve that speed. IIRC, this stuff isn't widely available on the consumer market yet.
Having a dual-band router doesn't mean you can bond the channels, it just means that you can have both types of clients connecting at once. At least at the moment.
So yes, it would appear that you got served.N300 / N600 seems to really be a "marketing" move. N300 is the true speeds as the 802.11N can max out @ 300. Marketing probably consider that since both the 2.4 Ghz and the 5 Ghz "radios" can do up to 300 each:
300 + 300 = 600
12.5 MB/sec from an N device to my gigabit htcp. compared to 2.5MB/sec with my old g setup.
both say 300+ 300 on the box. did i get fooled?
if you are thinking that you are going to get a trunked connection with a speed of 600Mb/sec, yes you got fooled. mostly your fault for believing in the box.
