I have an 80GB drive that I have set to slave and use as backup. When I have something important I just toss a copy on it. Well recently the drive has not allowed my PC to boot, If it is plugged in my PC will not boot into windows at all. After the windows loading progress bar it just locks up.
I have ran CHKDSK and its coming out clean and fine. I can even see the files through DOS Mode (can't write due to no support in DOS, Boot Discs seem to not be able to write aswell). My bios are even reporting the drive aswell so I cannot see any issue that could be causing this... I never seen a slave drive prevent windows from booting.
Now heres the kicker, I installed the drive into my roommates PC and it works flawlessly. He is able to load windows and even browse the drive within windows perfectly. I know its not the cables or PSU since all my other drives that are larger and faster work and I even moved it around on different cables and jumper settings just to test it out.
Any idea's?
Any idea's?
