Drive stealthing problem?
SVTLightning
Ok, just built a new computer using this case:
http://www.newegg.com/app/ViewProductDesc.asp?description=11-144-026&catalog=7&depa=0
And I'm having a problem with the drive covers. It has a little flap that folds down when you eject the CD-Rom and is supposed to fold back up when the tray goes back in, but the edge of the cd tray gets caught on the little door that folds down when you try to close it.
Anyone else have this problem or know how to fix it?
heh, i just ordered that case :D
Try taking the panel off the tip of your cdrom drive tray. You should be able to just pull it upwards and it will disconnect
Cool, I'll give that a try tomorrow. I was actually thinking about that but wasn't sure if you could take it off. Thanks.
SVT
