Drive Letter problems
Format _C:
I added a new hard drive to retreve data and now my letters are screwed up.
every thing used to be one letter bellow IE: F was E and it pisses me off and screws up my games. I used to remember how to fix it but I forgot. I'm running XP Pro thanks
Code:
Hard Disk
C:\
D:\
OPtical
F:\
G:\
Card Reader:
H:\
I:\
J:\
L:\
right click on my computer
go to manage
go to nearly the bottom of the list on the left
click disk management
start renaming drives.
Under your Admin tools, go to computer management, and select the disk management console. select the drive you want to re-letter and right click. Select change drive letter and paths.
Cheers,
EDIT: Bork, you're too fast!
Computers are a lot like air conditioners - they both work great until you open up windows.
LOL, dude that is absolutely hilarious!! :D
