tjwilco said:If you have a Harbor Freight in your area I'd suggest checking there before buying from Home Depot. I was able to get a 10 piece hole saw set for half of what Home Depot wanted for a single saw.
Nivram said:Harbor Freight is a good place to get a decent quality hole saw. Not sure if they sell the bi-metalic saws or not.
If you're going to be doing more than a few holes, buy a quality bi-metalic hole saw. They cut faster, and will last a LOT longer than the other (cheaper) style, which will start dulling out after just a few holes in steel (thru aluminum it's significantly longer, but still not as good as you'll get with the bi-metallic style).
I consider buying quality tools as an investment, especially as I've gone through too many cheap tools over the years. That's why I've got the bi-m hole saws in 60 & 80mm sizes. Thru 1mm aluminum, with my cordless drill-driver, that 60mm saw will cut thru in about 3 seconds!!
Qtip42 said:If you buy online, they're about $13 so just wait till they go on sale locally.http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=36222
