amdownzintel
- Oct 24, 2004
Ok so I bought a Dremel XRP 400 . I got the one with the box that came with a few attachments and drill bits and things like that. My question is that well I was cutting my stacker case (to mount a 3 X 120mm Radiator) and well first I used the drill bill to cut a hole in the case and that went fine. Then when I try to actually go forward and cut the case well
that's where a lot of noise and not a lot of movement starts to take place. I just tried using a cutting wheel which was provided and well within just 1 min. the wheel managed to snap in half and fly across the room. So my question is to you what do I do? Is there a certain bit out there that will do this a whole lot easier? Or should I just go buy a jig saw? Please respond quickly so then I can go to the store before they close. Thank You
