Ok, I'll start with the "caveats":
This is my first case mod.
It was done in 4 hours, with the tools my buddy and I could carry in one trip (advanced laziness)
It's not pretty.
It's functional!
Ok, I guess it's time for the actual unveiling...
I built a drawer-puter. But I kind of went beyond a regular drawer-puter. I have this huge desk (it has 2 x 19" and 2 x 17" monitors on it right now!) It has two hanging drawers; the bottom one was for "hanging files", so it had a nice steel "rim" around the top. I spent one night staring at it and measuring to make sure it would all fit...the next morning, I called my buddy, and we were on it.
I wanted to tidy up my network. I have a server (POS 300 AMD K6-II) that does DHCP, DNS and routing for my network.
But then I figured that just putting the server in a drawer wasn't enough...and the drawer is deep! So I put 2 switches, and a KVM switch in there too!
A: KVM switch
B: 5-port Netgear switch
C: CD-ROM drive (FD and HD are under)
D: 8-port Netgear switch
E: Motherboard
The KVM, 5-port switch and drives are hung from 1/4" plexi sheet. Where the "E" is in the pic is a 8" x 8" cutout for access. When the CD tray is open, it takes most of the opening:
But when it's closed, I can get to the other things I need to:
All you can see from the outside is one switch, and two LED's (my vid camera choked on the LED's):
(By the way, I don't have the keys for the locks...anyone help?)
With the drawer closed, it's really quiet. My super-scientific temp measurements (non-contact thermometer) show the case temp never goes over about 85F. I have two NIC's in there now, but I'm going to add a MODEM (ugh) so I can use it as a fax server.
Well, that's the general idea; I won't bore you with details (unless you want to be bored, then just ask!). Like I say, it's not pretty, but it does clean up my network a lot! (if you ignore the tangle of wires I haven't gotten to cleaning up yet) The upper drawer will fit another comp, too! Oh, and a gratuitous shot of my observatory, since I haven't seen anything but clouds for MONTHS!
Comments/criticism wanted!
It's not pretty.
It's functional!
A: KVM switch
E: Motherboard
