DRAM overclock issue
Kasumi-
Hello guys, I have a question. I've been trying to OC my RAMs and came up with a "problem". I have two 4GB 1333MHz sticks with NO XMP support, but my MSI board have a feature called 'Memory Try it', which helps achieve desired frequency.
I am able to set 2200MHz 11-12-11-29 1T, and running AIDA64 benchmark I get these speeds, which are inside expectations:
However, when I set 2400MHz, no matter what timings, and run AIDA64 benchmark, I get these ridiculous speeds:
Is there something wrong with my sticks? My board has like infinite options on DRAM part, is there something I need to enable? Also, I've read about this issue on X99 boards, perhaps it has anything to do with the dram mult?
Thanks in advance!
Dram fsb ratio 36:3 would be the cause if im reading that right......Looks like it just how your motherboard does at that dram speed setting.
