DarkenReaper57
- Oct 2, 2003
Ok, I am currently setting up my watercooling equipment in my new thermaktake tsunami case. The equipment is as follows:
D-tek Whitewater cpu block
D-tek gpu block
UV blue bay res
86' chevette heater core
Eheim 1250 pump
I had a bay res in my last setup (had to replace it though, since it cracked) and I realized it was a pain in the butt to drain the system. I ended up putting a t-line in at the bottom while keeping the res for draining purposes.
Unfortunately due to space limitations I may not be able to fit the t-line at the lowest point in my new setup, much less before the pump. I'll probably post some pics in the morning but now I just need to get some rest and get away from working on it.
So, those of you with bay res's, what do you do to drain your system without making a mess?
D-tek gpu block
UV blue bay res
Eheim 1250 pump
