mephisto1961
- Oct 11, 2010
Yesterday I tried to configure my DVI triple monitor Asus 24" using a "certificated" Sapphire active adapter DP>DVI single link on the third monitor (5760x1080 32bit landscape option) Window 7 64bit , but it doesnt work.
Infact when the monitor under Dp port turn off (in example during bazel configuration or in game before to drive) than doesn't turn on until I unplug dp adapter and then plug newly.
I wish to use triple monitor for Sim racing with RFactor as I saw in several wonderfull video on Youtube, but when I try to drive on game (all 3 monitor active) the one under dp adapter stay blak. My cofiguration as follow:
Driver Packaging Version 8.771-100825a-104558C-ATI
Catalyst Version 10.9
Provider ATI Technologies Inc.
2D Driver Version 8.01.01.1071
2D Driver File Path /REGISTRY/MACHINE/SYSTEM/ControlSet001/Control/CLASS/{4D36E968-E325-11CE-BFC1-08002BE10318}/0000
Direct3D Version 8.14.10.0779
OpenGL Version 6.14.10.10188
Catalyst Control Center Version 2010.0825.2146.37182
hardware:
Primary Adapter
Graphics Card Manufacturer Powered by ATI
Graphics Chipset ATI Radeon HD 5800 Series
Device ID 6898
Vendor 1002
Subsystem ID E140
Subsystem Vendor ID 174B
Graphics Bus Capability PCI Express 2.0
Maximum Bus Setting PCI Express 2.0 x16
BIOS Version 012.019.000.002
BIOS Part Number 113-C00140-00I
BIOS Date 2010/02/03
Memory Size 1024 MB
Memory Type GDDR5
Core Clock in MHz 875 MHz
Memory Clock in MHz 1250 MHz
Total Memory Bandwidth in GByte/s 160,0 GByte/s
May anyone of you help me?
Many thanks!
hardware:
Primary Adapter
Device ID 6898
Vendor 1002
Subsystem ID E140
Memory Size 1024 MB
Memory Type GDDR5
Many thanks!
