KingThot said:I'm thinking the biggest problem is that the dothan don't have heatspreaders like the usual P4's. I may work though. By the way what type of performance are you getting out of your dothan I've heard of them beating P4 EE's and FX-55's.
i815 was the shitwidefault said:The 1.6Ghz@2.13Ghz replaced a P4 2.4C@3Ghz and is every bit the equal or better in performance, using about 1/4 the power. It's also been the most stable PC I've had since a PIII Tualatin on an i815 chipset.
