ninethreeeleven
TKer
- Jul 16, 2004
I'm was thinking about cutting the Doom 3 logo into the side of my case, but then thought that might be to bland, so I came up with this idea, that anyone can use if they want. I didn't light the "plainness" of the Doom 3 logo, and this is what came from thier website.
I took the original pic from a screencap from www.doom3.com
Since then I modified it to get the lines so that I could cut them into my case (as well as a good outline of the designs surrounding the main circle). I am not very good with paint shop pro, but I just wanted to find out the corners and the full design of the "symbol" I think with a compass and some good measuring this could be done, but not easily.
Anyway on with the show...
Original Pic
First draft (blacked it in some)
Cut lines blurred
Cut lines sharpened
You can really see the symbols in the last pic, maybe it would be to hard to cut them out in thier present location, but placing them somewhere on the case would be a must if it ever gets done (or started for that matter).
You can also see where the "Doom 3" started to fade into the pic (top left corner), I had to reload the Flash site a bunch of times to get it to where the symbols got into thier place, but the "Doom 3" didn't show up.
Original Pic
Cut lines blurred
Cut lines sharpened
