evilangelic
- Jun 12, 2008
Hi, just two quick questions...
1) Does Stock AM2 Cooler fit on a 939 Socket Board?
2) Copper heatsink discolouration, does it matter?
Thank you for your unlimited knowledge!
I have a Scythe Ninja 2 w/ 120mm (can fit a variety), on my 939.
I want to swap it with my AM2, which currently has the stock cooler on it.
I don't want to take the AM2 cooler off without knowing that it will go on the 939 board.
They look pretty similar, are they the same size motherboard mounts?
I have googled but am unsure.
The second question is, the Scythe Ninja 2's copper contact plate is discoloured on the contact surface.
It has dark patching of the metal. Is this usual due to the heat? It is still seemingly perfectly smooth. (It has been in use for a while).
I don't have a picture right now as it is applied to the 939 board.
