thenerd said:so where should i place them in the case? i'm noob so i don't know which is intake/outake
JackieChanIsGOD said:hehe...
Well, at the back of your case, there should be two places for the fans... put the top one exhaust (blowing outwards) and the bottom one intake (inwards)...
Then at the front, you can have one intake, and if you have a side panel hole, have that one intake too... if you want... that should be good.
thenerd said:??????????????
so what should i have at the back? 2 exhausts?
correctthenerd said:thx guys,
so what if i have 4 fans? should i go with 2 front intake + 2 back outtake and ignore the top and side fans?
thenerd said:it seems like i'm getting a case with 2 back, 4 front and 1 side.
would buying an extra side fan make a big difference?
