Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
When not overclocking the video card, and keeping the agp locked at 66, does AGP voltage effect the stability of your overclock? Have you found that running at 1.65V versus 1.55V affects anything?
some people insist that the AGP voltage in an intel board is directly related to the NB voltage, and will help an overclock. Others insist otherwise.
In my experience, raising the AGP voltage increases stability when overclocking, even raises a max overclock. So, I say yes. But just play with it yourself.
In some cases it can help with stuttering issues, and I've heard of ATI actually recommending it in such cases (Rage3D postings, so don't quote anyone on that ).
Keep in mind that it dictates the AGP controller voltage and not the voltage in the card itself so the AGP controller is likely to give out but not the card. Of course the AGP card wouldn't work any longer but a PCI card usually works... then you'd be stuck with lowend vid cards until a replacement mobo can be picked up though
Personally I've never seen an AGP controller fry, but as a rule of thumb, only raise it to alleviate problems, and only by as much as the fix requires. Usually anything less than 1.8v is fine.
I've had the quality of an OC affected by the quality of the thermal interface between the 9800 core and heatsink. Not that it made the OC STABLE - without AS3, I couldn't boot @ 262 bus, with I could. Neither was stable. And yes my AGP/PCI bus ratio was fixed.
