I usually don't post questions like this but we are all stumped.
The symptom is one of our client servers (HP DL380 G6 for this particular one) has developed a randomly issue where it loses name resolution, causing the server to fail to communicate with the domain controllers and any other network resources you try to ping. Our environment is running in native 2003 functional level with about 28 thousand servers, we have multiple DNS servers that use BigIP VIPs for round robin, etc...
DNS settings are on the particular client server are verified correct, all tcp settings appear good, teaming set to failover only, etc... When it happens, nslookup queries fail, even when you specify the DNS server. We can get around the AD issue by adding the DCs to the hosts file but that only addresses the AD communications, other communications requiring name resolution still fails (we can't add all target systems in the hosts file, as the servers application has to open connections to thousands of agent PC's that use DHCP).
We have done dnsclient restarts, winsock and tcp/ip resets, changed network drivers, updated firmware, etc. So far, the only workaround we have is rebooting the particular client server, then everything works fine for a few weeks to a month but the issue returns eventually.
Anyone been able to find a cause for such a weird issue? So far we have only had about three servers over the last few years that developed this issue.
