Displaying PC on TV (questions)
deadman_uk
Hi,
I have a 7900GT and a cheap 28" JVC TV. I connect each other up with a SCART to S-Video (with 3.55mm phono jack)
http://cgi.ebay.co.uk/2m-SVideo-3-5...ryZ32837QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
The S-Video cable plugs into my graphics card, the phono cable to my soundcard and the scart to the back of my TV. I can now see my PC on my TV using nView.
My friend wants to do the same... he wants to run a computer game and have a clone image sent to his TV (so he can play on the TV). You can do this with my current setup but I have a few questions before my friends buys this cable.
1) Does my friends graphics card have an S-Video port? I haven't had a chance to visit him recently, so I cannot look and my friend is away for a week. He has a 6600GT 256mb.
2) I heard S-Video isn't very good quality, is this true? On my setup, watching videos on the TV from my PC is very clear, but the desktop icons etc are not very good quality on the TV (this could be caused by my cheap TV) Can anyone recommend any cable that will give him better quality and still work with his graphics card?
3) Is there another way to get sound other than this phono cable? His pc is pushed up against the wall, in between a gap. To have sound sent from his PC to his TV, he would have to unplug his speakers and plug his phono cable in the soundcard port, which is a lot of hassle. The PC would have to be pulled in and out all the time.
Thanks for any help.
1) I have no idea if your friends card has SVideo, you'd best ask him :)
2) SVideo is meant to carry PAL and NTSC TV signals which are pretty low res by PC standards, around 640x480 for comparison.
I find that 800x600 res is very acceptable and at a push 1024x768 res can be used if the card supports it.
If you arent worried about reading text, try 1024 res as it may look a little more detailed with video.
The cable quality will make a small difference, you may not even notice it though.
The biggest detractor to the quality will be the cables length, keep it short if possible.
I wouldnt worry about which cable you get but if you really do want to make sure, goto a hifi/video shop and get a quality cable.
3) You can buy a switchbox that will allow you to switch the sound output of the PC to different devices.
If the TV only supports stereo you will only need to switch the front stereo pair of phonos.
You will also need to turn off 5.1 sound on the sound card to prevent loss of sounds to the TV and prevent surround sounds coming from the hifi while using the TV for sound.
Another alternative is to use either an Optical cable or an RCA connector (single phono) for Digital to your Amplifier, as long as the PC sound card and Amplifier support the same connection.
You will only get stereo PC sound with digital though unless watching a DTS (Dolby Digital 5.1) source like a DVD movie.
The TV is connected via analogue phono.
You would then switch between them by selecting analogue or digital sound in the driver for the sound card.
You could do what I have and position the hifi around the living room so the TV is central to it and the use the hifi for TV sound.
Ok, I googled "6600GT +s-video" and it appears all 6600GT's have an S-Video port but I will check this with my friend when I speak to him next.
Well he only wants it for games and maybe video, not for viewing webpages or text. I think this will be ok.
My cable is 10m! and the quality I would I'd say it 7/10 for computer games. So my friend should expect slightly better quality if a 2M one is purchased?
How much would a switchbox cost? This is suppose to be a lost cost way of playing video games on a larger screen.
My soundcard is 7.1, I don't experience any missing sounds on my TV. What exactly do you mean here?
It means you have nothing to worry about :D.
Shouldn't concern you but if it does, you know what to do. :p
Cool :)
If you were to use a 2m cable it would probalby look a bit cleaner but I cant vouch for what his TV picture will look like compared to yours.
You could try both cables on his setup to see if you can tell the difference.
Sorry I cant help, I'm a bit out of touch with prices or where to buy.
I'm UK based btw so dont know about American stores.
When you switch the sound from your front pair of speakers to the TV, the other 5.1 sounds will still come out of your hifi. This also means those sounds will not come out of the TV.
To fix this, set your speakers to Stereo (2.0) so all sound goes to the TV.
I use a 10m cable because the TV is very far away from my computer, if 2m is better quality I will still be stuck with the 10m cable anyway lol.
Did you not see the UK in my name? lol I am UK based too :p
Thanks, you have been a lot of help.
I started writing something... and then realized you were dealing with SCART, and in the UK, and I know little to nothing about SCART, just S-Video, component and composite YPbPr we use here in the US. Sounds like you got it figured out, though.
oops about the uk, I just got back from buying a car along way away, am still knackered but smiling.
If I needed an audio switchbox, I'd probably make one myself from parts now . RS or Maplins sell everything you will need from the connectors + wire + switch to the plastic box to put it in.
If I couldnt be bothered to make one, I'd see what the hifi shops sell, they will be sure to have or be able to get something that will do the job.
I have something here which will do the job but I use it.
Its a CD player volume control/switchbox made by QED, It can switch one of 2 sources to 1 output, or 1 source to one of 2 outputs, one has a volume control.
Its about 15 years old but I imagine the company is still around.
You may be able to use the manufacturers name for reference when asking about switch boxes.
Happy to help, I hope you get a nice solution.
You have been of great help, thanks very much
