Originally posted by mitch808
turn off DHCP? With no IP, there is nothing to route.
Originally posted by O[H]-Zone
You already own a switch. If you'd like to purchase another, by all means...go right ahead. The switch that you already own is built into the router you already own. Now, if you'd like to listen to the advice everyone has already given you, you can use the switch that you already own. If not, you will be unable to use the switch that you already own.
