Difference between + / -
From the DVD Demystified FAQ,
http://www.dvddemystified.com/dvdfaq.html#4.3.6
As explained in the previous sections, there are two main formats: "dash" (DVD-R/RW) and "plus" (DVD+R/RW). There's not much difference between them. They both record data and video, and they both read back data and play back video. Both formats are available as recordable drives for computers and as home video recorders. In spite of claims that one format is more compatible with players and drives, both formats are similarly compatible (see 4.3.1). There are speed differences, but it's a game of leapfrog. One format will come out with faster write speeds, then the other one will match it or surpass it. In 2003, drives reached 8x speeds. 16x is the theoretical maximum, so both formats will soon hit the limit.
The biggest thing to worry about is that DVD-RW drives only record on -R and -RW discs, and DVD+RW drives only record on +R and +RW discs, so you have to make sure you get the right kind of blank discs. You may worry that one of the formats might "win" and the other format could disappear, leaving you with abandoned hardware. This is not very likely, since both formats are doing well. Luckily there is a simple solution to both concerns: buy a dual-format, or "combo" drive. Many companies make DVD-/+RW drives that write to both kinds of discs. Dual-format drives cost a bit more, but it's cheap insurance.
The DVD+RW format has a few advantages when used in a computer, but if data backup or access speed is important, also consider the DVD-RAM format. DVD-RAM is fast and reliable, and the discs have an optional cartridge to help protect data. Most DVD-RAM drives also write DVD-R/RW discs, and some super combo drives write all three formats.
Also read sections 4.3.3 and 4.3.5 for more detailed info on DVD-R/RW and DVD+R/RW, respectively.
they are different standards. most newer dvd burners work with +, some older ones only work with -
i think the difference between the coding is minus doesnt have error correcting or something + is supposed to be a better format
we have a burner at work that will only burn to - disks, i didnt even know there was a difference till recently.
here are the exacts if you feel like reading
http://techreport.com/etc/2000q4/dvdrw/
Are you asking what media to purchase for your burner which supports + and - media, or are you trying to decide between + and - burners?
