MaXimus666 said:So what matters at teh end of teh day is teh size on teh disk eh? since that's the end result of diskspace used.
It depends on what is important at the end of the day. If disk space matters, then yes, disk usage will be your main concern. If you're transmitting the files over a network or something, then disk usage will be of no concern whatsoever; all that matters is the size of the file itself.MaXimus666 said:ah thanks for teh clarification.
