The speed is faster, the cables are ALOT smaller and more convienient, they are the "future"....and they cost the same if not less, as in my case.Dutt1113 said:I've always had ide harddrives. I've never had the chance to buy a sata harddrive. what is the difference. Is it just loading times? Is it a noticeable difference in speed?
HighwayAssassins said:The speed is faster,
the problem seems to be you have never actually used a SATA drive...only for RAID or for a PCI card would you need to push F6, and even then, it is easy and always works for me.WickedAngel said:The main difference?
SATA drives seem to be a pain in the ass to get working. Trying to get a Windows XP isntall to recognize them is like trying to shoot a fly in the dark...
HighwayAssassins said:the problem seems to be you have never actually used a SATA drive...only for RAID or for a PCI card would you need to push F6, and even then, it is easy and always works for me.
