FatteyMattey
- Sep 5, 2001
Can anyone tell me what the difference between the 15pin D-sub and the DVI-D connections?
Everyone says DVI-D is better but I'm not sure what makes it better. Is it worth it paying a lot more for a monitor if it has that option?
Right now I'm looking at two LCDs, one is cheaper and doesnt have the DVI, one is quite a bit more expensive but has the DVI-D option.
Also, about response time. If I play counter-strike off and on will a 25ms bother me? Or lets say I eventually get around to Doom3. Would Doom3 just be unplayable?
