If I remember correctly from my NEC that was the same monitor rebranded I used the test patterns in the control panel software. I could never get a perfect calibration across the screen but you should be able to get at least 95% close. You'll mainly be having problems focusing the outer corners.
As for which pot does what I can't remember exactly. You just have to play with it and get a feel. Or Google-Fu
