Diamond Plate Case: Progress continues
s10010001
Under side of the top panel….still need to wire the LEDs but my soldering iron decided to die…
Top side of the top panel, mmmm manly bulky knobs….and chrome LED Housings…
Installed on case…..the off and full speeds setting on the dial start and stop just before it hit the LED housing…..so you cant hit it…
Back side of need front panel….the plate for the CDROM is held on by rivets. The tape is just to keep the light form the LEDs form poking its glow out the CDrom….
CD-Rom access from the front….note that the diamonds were grinded down to fit the plate flush….
Installed: note the leftover 2-sided-tape form the last stealth installation…lol ohh well.. ill clean it up later…
Fan…120mm…need a new one this one is silent only like 40cmf or something… will replace with at least 80cmf… This ugly hole is awaiting a nice mesh grill, but I haven’t found the right stuff yet.. I’m still looking for something to use…
Bolts to hold panel on…there are spacers in between the panel and front of case…so I can tighten the shit out of it without bending the thin case into shreds…
And this is what it looks like all together so far…i added some mroe chrome LED houseing on the front for the Power LED and HDD led... didnt take a close up of it though...
well anyways… that it… hope you enjoy…
nice work, but the topic is a bit misleading, I came in expecting an entire case from diamondplate, cause ive always liked that idea.
oh well, nice work none the less, ever think of cutting pieces for the insides to hide wires?
Well that would be cool, but the sindie is so tite with all my stuff, yet supriseingly easy to work with, all the wires are pretty much hidden.....the case layout of great for hiding wire..ill get pic of that when i get there, but im still working on the outside...
