Toilet Duck
- May 22, 2005
At the moment, I'm using the college's ethernet connection. It's pretty lenient; every game I have seems to work, download speeds are fine, and I'm generally happy with it. However, it does appear that Bittorrent/Bittornado have been stopped, somehow (or rather, they are the only thing I can't get to work).
I also have a 56k modem/connection available. Lately, I've been disconnecting the LAN, dialing up, and downloading/torrenting slowly but surely overnight. I tried activating both connections at once, which works.. but without the desired results. It seems like the 56k connection overrides everything.. the LAN just stops getting used, period.The second I disconnect the 56k, the LAN gets all traffic again.
At any rate, my question is this: Is it possible to have both connections simultaneously running, with the 56k being delegated/restricted to Bittorrent related traffic and the college ethernet handling everything else, or some similar setup?
The only other semi-relevant thing I can think of is that I'm using XP Professional, SP2 with all updates... thanks in advance for any advice.
