Superhuman
- May 19, 2006
Just saw these posts by Blizzard on the official D3 forums:
Are you fucking kidding me, AMD? This is easily the biggest release of 2012 so far and the most current drivers are gonna have problems launching the game, let alone actually running it? Unbelievable.
Ugh. I guess my question is... which version of Catalyst should I install since I'm going to be doing a fresh install of Windows 7 on my new SSD? 12.2? 12.3?
I've been notified that the current Catalyst 12.4 release drivers aren't going to be supported for use in Diablo III. Either revert to an earlier release or maybe the 12.5 release
As of right now, tonight, the word I have is 12.4 will not be supported on release. That could change between now and then though.
Catalyst 12.4 drivers aren't supported. You'll need to revert to an earlier version.
12.2 can be found here: http://support.amd.com/us/gpudownload/windows/Pages/radeonaiw_vista64.aspx
I did a little checking after I last posted and apparently, the 12.4 release is having enough issues right now that we're going to post that warning you saw if they're detected in use. The best solution, again for now, is to revert to a slightly older release. This is subject to change at any time, but for now, it looks like it's going to continue on into release.
