Hey everyone,
I've got a bizarre problem here, and I suspect it's PEBKAC, so I need a bit of help. The summary: DHCP works, static IP does not!
With a static IP address, my computer can access the router configuration page, but that's about it (sounds like default gateway issue). I can "occasionally" get some content off the internet, but by and large, most HTTP requests fail. I think the ones that succeed may actually be from the browser cache. I can't even access my cable modem HTTP setup page (192.168.100.1) with a static IP configured.
Setup: One machine, Vista 64 + SP1 final through Windows update, Linksys WRT54GL router, attached via a CAT5 cable. Note that I've tried a couple different addresses, and my machine is the only one on the network. Just for grins, I assigned it the same address I received from DHCP, but that didn't work either. Go figure. I'm concerned this may be an SP1 issue, since it started right about when I got that installed.
I suspect a default gateway misconfiguration of some kind. Another odd thing is that when I switch from DHCP to static, type in the address/mask/gateway, click OK a couple times, there's no default gateway assigned. When I go back to the TCP/IP v4 properties, the gateway is blank. ipconfig /all reports no gateway, similarly. If I _then_ type in the gateway, click OK a couple times, it "sticks." This is obviously screwed up, and suggests a misconfiguration somewhere, e.g. some registry nonsense?
Here's my ipconfig /all setup with a static IP that does not work properly.
Any ideas?
Here's the same ipconfig /all for the main network adapter when configured as DHCP. This setup works fine, as I'm using it to post now!
Any ideas?
Code:
Windows IP Configuration
Host Name . . . . . . . . . . . . : Core
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Realtek RTL8168/8111 Family PCI-E Gigabit
Ethernet NIC (NDIS 6.0)
Physical Address. . . . . . . . . : 00-17-31-88-A0-D1
DHCP Enabled. . . . . . . . . . . : No
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::b46e:f842:751:348c%8(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.222(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.1
DNS Servers . . . . . . . . . . . : 192.168.1.1
NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter AFS:
Description . . . . . . . . . . . : Microsoft Loopback Adapter
Physical Address. . . . . . . . . : 02-00-4C-4F-4F-50
IPv4 Address. . . . . . . . . . . : 10.254.254.253(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.252
Default Gateway . . . . . . . . . : 0.0.0.0
Ethernet adapter VMware Network Adapter VMnet1:
Description . . . . . . . . . . . : VMware Virtual Ethernet Adapter for VMnet
1
Physical Address. . . . . . . . . : 00-50-56-C0-00-01
Link-local IPv6 Address . . . . . : fe80::8115:ca3:956b:5c18%12(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.88.1(Preferred)
DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
Ethernet adapter VMware Network Adapter VMnet8:
8
Physical Address. . . . . . . . . : 00-50-56-C0-00-08
Link-local IPv6 Address . . . . . : fe80::4d9e:4018:fe3e:5601%14(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.23.1(Preferred)
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
Tunnel adapter Local Area Connection* 6:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : isatap.{CC8C5076-94F9-4D34-AB0E-4703FFA2F
B3C}
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
Tunnel adapter Local Area Connection* 7:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Physical Address. . . . . . . . . : 02-00-54-55-4E-01
Tunnel adapter Local Area Connection* 9:
Description . . . . . . . . . . . : isatap.{1BDBBE95-5B29-4782-97B6-09D0249E8
FAC}
Tunnel adapter Local Area Connection* 10:
Description . . . . . . . . . . . : isatap.{1BC56494-9DAC-48B5-88FD-0A05CC3C2
964}
Tunnel adapter Local Area Connection* 11:
Description . . . . . . . . . . . : isatap.{C6C61721-4A19-48A5-8F38-C38C6D07D
C9B}
Code:
DHCP Enabled. . . . . . . . . . . : Yes
IPv4 Address. . . . . . . . . . . : 192.168.1.111(Preferred)
Lease Obtained. . . . . . . . . . : Wednesday, February 27, 2008 2:16:33 PM
Lease Expires . . . . . . . . . . : Thursday, February 28, 2008 2:16:32 PM
DHCP Server . . . . . . . . . . . : 192.168.1.1
