Hello folks,
I just picked up a DGL-4500 to replace my DIR-615 which was working well enough, but I figured I could bump up my wireless range/speed as well as my LIVE connection at once.
The problem is that for some reason, my DGL just won't be seen by my PowerMac G5 when connected via hardwire for longer than a couple seconds. At best I'll get a constant cycle between being connected and my G5 thinking the ethernet cable isn't plugged it. I don't have Airport built into my G5 so I'm unable to test that.
I've been able to connect to the DGL wirelessly from my Intel MacBook with no issue (allowing me to upgrade the FW to 1.01) and I've even connected from my MacBook via a hardwire connection which I won't ever do, but just wanted to test to verify it was possible.
It's really strange because the DIR-615 has been totally fine connected to my G5 and is once again. I've used the exact same gear minus the AC adapter to no avail, tried multiple resets/power-cycles and alternate cables just in case etc.
The box states the DGL works with Mac OS X 10.4 or higher. I'm running 10.4.11 on both machines, just optimized for different processors. D-Link tech support was quick to get me off the phone since their hardware does actually work, just not with my G5 I guess.![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Has anyone out there had any success with this router and a PPC machine? Anyone have any suggestions or know whether or not my built-in ethernet could simply be too old for such a new router? Are there any PCI network cards I could use that will for sure work? If nothing else works, can I combine my 2 routers in sort of a diasy-chain type deal so I can at least use the DGL for my wireless?
Thanks in advance for any help and sorry for the length!
