- Aug 20, 2008
Post links to stable ABS profiles that work with your machine.
Include a description of the profile and information about your build and any special instructions.
I'll start.
DFI P45 JR T2RS bios date 08/12/2008
Intel Q9400 OC to 3.6GHZ
RAM Corsair PC8500 Dominator 2x2GB
RAID 0 hdd configuration
PSU Corsair TX 650W
Air Cooled.
SAVE ABS Profile for Q9400@3.6GHZ from here: clicky
Must be loaded from the ABS application. In the BIOS select BANK 4 for my settings.
Bank 1-3 are from the standard DFI upgrade automatic upgrade options.
I highly recommend everyone run memtest86x from the BIOS before booting up to Operating System. This will check to see if the RAM timings and settings are compatible with your machine.
WARNING
Use these profiles at your own risk.
NOTE**** My profile has the PCI Express set at 105% which works great for my Toxic HD4850. You may want to manually set it to 100% before trying the profile out. Also check the BIOS for any other known settings that may cause a problem with your build. Again I highly recommend running the Memtest86x from the BIOS before booting up to prevent OS getting corrupted.
ALSO you may want to make sure your DATA is backed up before trying these profiles.
I'll start.
PSU Corsair TX 650W
Air Cooled.
WARNING
