bigstusexy
- Jan 28, 2002
This is a windows issue I'm sure of it
i'm trying to install a network card into windows, someone this became FUBAR way before I touched it and its still so. The problem was that windows had a fantom card, it was saying that the current network card was the seond one of its kind in the system, not that there were two but the second. Like if you install a card (network) and them move which slot its in, windows will somtimes recognize it as a second card and even though it won't show you the first it still believe that its comming back. This card is intergreated into the board so that wasn't what happened.
Long story short, I removed the card from the registry, booth of them and uninstalled the drivers and any instance I saw in device manager, I went to reinstall it now I'm get this generic, Can not find file specified error, tried anoter card (3com was the only thing I had on me) this card should have drivers 100% built into windows, it gives the exact same error when trying to install it. I have a usb to ethernet adapter... works fine.
Anyone seen this before or have any leads on how to resolve this?
