D
Deleted member 88301
Guest
Hi, all.
This is probably somewhat basic stuff to a lot of you. I have a T3500 system which is just an old server. Mine has the "better" HS that has heat pipes, as compared to the basic model which is just an aluminum block with fins. Neither one comes with a fan installed on it, though one can be easily installed, and I will do so soon. The two front fans don't kick up the RPMs until the CPU temp gets close to 90 or so C. So Prime95 would almost instantly scare me with temps.
Well, I got some info from a YT vid on how to use Speedfan to set the front fans to whatever RPM I want. The "secret" was to set SF to use Dell laptop configs. Yep, my computer now sounds like a junior fan blower. But Prime95 hasn't raised my CPU temp above 61C. I can maybe set profiles in SF, not sure yet. It's just a shame that the BIOS won't let me do anything about fan speed. This is a minor victory to me, LOL!
Again, as my rig is pretty old, this stuff is probably pretty boring to most of you guys.
Wyo
Wyo
