I`m guessing 40x40x10!?
They`re pretty common sizes whatever they are.
Depending on why they`re noisy, you may be able to quieten them down in about half an hour.
If they`re noisy cuz they`re loud, fast noisy fans then they need replacing, but if it`s cuz they`re all grumbly cuz the bearings have dried out you may be able to breathe a few more months of life back into them with some lightweight household oil.
DO NOT USE WD40.
Obviously these are two different reasons for being noisy, both requiring two different methods of silencing.
Dash`ll be here soon with some pics of some fan modifications he`s done and some recommendations for some makes/models of fan to use, as well as how to run them slower on 7 volts or even 5 volts.
Either way, there are a few options....
**edit**
Holy mother of god! They`re 9000 rpm Delta`s
That`ll explain the noise then! They`ll need slower/quieter replacements, no amount of re-lubricating will silence them!!![]()
Yea, they are loud LOL.
I'm looking at fans on newegg, and was wondering if anyone has fit 40x40x20mm fans in it. Or if they are sticking to 10mm. I also have heard I may have to mess with the wiring. I could just crack open my switch but I prefer not to without knowing whats all involved.
I don't recommend downsizing/altering/eliminating fans in switches. If you want a quiet switch, get a Linksys consumer switch or a fanless switch with the features and warranty you need.
Otherwise put the switch where noise won't be a factor.
I know good success has been reported with altering fans in switches, but it just sends the bad chills down my spine when I think of it. 40mm fans are only going to be varying degrees of loud, they could not be accurately described as quiet unless they are dead and burried.
To some degree I would agree, certainly with some equipment but a standard Gb switch, only a 24 port and no POE, I`d still stick with what I already posted...
In the home environment you`re never gonna see the temps that these switches are designed to cope with in the environment they were designed to live in, So, take from that that you no longer need to move so much air to cool a device that will not be running so hot in the first place and you can safely choose slower/quieter fans that move less air and live safe in the knowledge that the switch won`t/shouldn`t overheat.
Of course, this is my opinion and they`re like assholes.... everyones got one, but I think it goes without saying that any mods or changes to any of your own kit, whether suggested by me or whoever else, if any given user decides to make those changes to his own kit then he does so at his own risk.
But a standard, non-POE, 24 port switch in a home environment, I wouldn`t think twice.... but that`s just me...
A 6 port switch....
Posted from Hardforum.com App for Android
dashpuppy said:Quote:
Originally Posted by BigBadAl
A 6 port switch....
NSA2400 firewall
So, what did you guys end up doing? The noise is really bad!
I'm thinking of replacing the fans, are they 40x40x10 or 40x40x20?
