I have 2 Dell 3007WFP-HC monitors, and I would like some help.
I've been reading a lot about how to calibrate the screens, and I've come up with some articles saying the there was a Hidden Service Menu available for the 3007.
First of all, is that thrue ? Second of all, How do I make it appear ?
I've read those 2 possibilities :
The general procedure for monitors manufactured in 2005 or earlier is as follows [e.g. 2005FPW]:
Press and hold the "AUTO" & "+" button (some models use "ENTER" and "+" button), then power on the monitor.
Once the monitor is on, press the "MENU" button to open the osd menu.
Now, in the osd menu, go to "factory reset" and you can see at the bottom of menu have an extra menu item named "FACTORY".
Go to that "FACTORY" selection and press the "ENTER" button.
You are now in the Dell service menu.
The general procedure for monitors manufactured after 2005 is as follows [e.g. 2007FPW]:
Press and hold the "AUTO" & "+" button (some models use "ENTER" and "+" button), then power on the monitor. Keep holding all three buttons until the monitor is fully on.
After the monitor is on, release the buttons and press the "-" button.
The factory service menu should appear.
My other question is. What is the AUTO and MENU button and the + and - button as well ? Are the + and - on the keyboard or screen ? If on keyboard, the ones on top of the enter button or the ones near the numeric keyboard.
THANKS again for all the help.
And if it doesn't work, what would you suggest for calibrating it?
