I'm helping a friend install new computers in his office, and one of the systems was ordered with a Dell 2001FP monitor. The systems are Dell Optiplex with some sort of nVidia AGP video card (not sure of the model or specs).
The 2001FP was working great for about three days, then this morning they tell me it wouldn't wake up from power save mode.
I went over there and sure enough, nothing we could do on the system would wake it up. The PC was definitely on (we could ping it and connect to network shares on it), and we power cycled it several times to try and get the 2001FP to wake up, but no luck.
We swapped the AGP card with another system (they ordered multiple ones, so all the vid cards are the same). Same thing. So then we took one of their 17" Dell LCDs and hooked it up - no problems. Then, we took the 2001FP and plugged it in and it worked!
So then, we restarted the PC and the 2001FP again wouldn't wake up when the system came up. Cycling the source selection back through to the DVI input, it still said the system was in power save mode, when clearly the PC was up and running.
Anybody have similar problems, or a solution? I'm on hold with Dell right now, and hate to have to return it if there's a simple solution. I also tried searching the forum posts, but I noticed the admins have turned off searching
Any help greatly appreciated!
Thanks
Thanks
