Defragment question
WarriorX
Quick question
When I defrag my HD, will it slow/hurt the process if I run programs, or surf the internet?
Thanks
Quick question
Thanks
A little bit, and the files accessed will not be defragged, but defragging should not be a "benchmark" so you shouldn't care. And if you do.. you need help.
Slow the process? Yes
Hurt anything? Doubt it
Why would you want to run defrag when you're using your box anyway?
I always run defrag in safe mode when box is not in use... but that's just me.
Thanks for the responses. I was just wondering because sometimes I would start to defrag, and needed to browse the internet for something. So I wanted to know if I should stop it or let it continue.
I've noticed a slight slow down (machine response, not internet) when defraging. I don't see a reason why you shouldn't defrag.
