Define R4 with two AIO Question
Will there be a space problem if I mount a H100 up top for the CPU and a H60 in the rear exhaust for the GPU? I'd like to do this for more of a simplistic look. If I can't fit the H60 in the rear exhaust, I could just bottom mount it.
Could a H110 fit up front?
unless you do not change the tubing on the corsair h110 you can't it on the front of the case.. also i do not think that case thave the space enough to fit the h110 on the front, remember its a 280mm radiator with a length of 312mm.. the most you can fit on the front its a 240mmx27mm radiator.. so the h100 or h100 can make it good but needing larger tubing and im not sure if in that case should be fine put a radiator in front as the intake air that receive the fans are fron the sides so the air to keep fresh the radiator will be poor...
and for the mount on a h100/h100i top + a h60 rear.. i guess you could have some problems there too.. by the position of the top mounting holes being too rear and the rear fan its a bit high.. so that could difficult the positioning on both radiators..
Just looked it up, H100i fits perfectly fine up front. And then a H60 in the bottom taking in cool air. Totally forgot I am getting a new desk, so the tower won't be a stationary vacuum on the carpet.
