Oct 20, 2007 #1 W wheelsx45 n00b Joined Sep 22, 2007 Messages 40 Should I leave all the voltage options to auto since I am not overclocked ATM? What is the default cpu voltage suppose to be so I can set it manually because I think auto might be setting the voltage to high for the cpu..
Oct 21, 2007 #2 C calvieee Limp Gawd Joined Sep 7, 2006 Messages 256 look at the vid from cpuid then set it as ur cpu vcore. if not, 1.3v should be plenty for 2.4 default clock
