madcat20xac
- May 13, 2008
so all i did was put another cooler on my cpu and now it doesn't boot. Doesn't look like i got as5 on the contracts because it looks totally clean. could it be that i put too much pressure on the ihs and broke the die itself? i'm thinking that's unlikely because i used a bolt down kit and i would assume it takes ALOT of pressure to break it through the ihs. Also i have a e4500, so they use thermal paste between the ihs and die instead of solder making it even harder to break from pressure.
here's some other information, ok so nothing shows up on the monitor AT ALL. the cpu fan is a 4 pin, and when there is no cpu in the socket the cpu fan will spin up, but when i put th e4500 in the cpu fan doesn't spin up.
