Dead A8N-SLI or 3200+? HELP!!!
Jutny
I got some new parts in the other day
a8n-sli
3200+ venice
xfx 7800gt
antec 550w tpII
to go with my
36gb raptor
3x 120gb special editions
audigy2 etc....
so anyway, i get everything installed and nice and neat, fire it up and everything looks great, checked bios settings, left everything stock and booted to a XP64bit cdrom. I installed and got into windows, installed nforce 4 chipset drivers 6.69 and restarted. I had just installed forceware 81.95 and was going to restart in a second when the computer just shut off completely unprovoked.
upon restarting nothing happens, no POST no beep no nothing, just the hdd led on constantly, all fans run and the rest of the system is ready to go. I stripped it down to everything including pulling the cpu and nothing at all, so i assume its the motherboard. i also checked if it was grounding out and same symptoms.
so basically, am i wrong?, could my cpu also now be screwed and it appears i cant rma either of these through newegg even though i got them yesterday and today respectively (is this really the case?, cause thats suckass)
and if i do have to go through asus, whats the fastest way to get a new motherboard from them, cause i NEED to have it soon for a bunch of reasons some of which include letting down family for the holidays (donor parts and such, long story).
thanks in advance, i was so excited to tear up some of the new games, and now this :(
-Kurt
usually you can rma to newegg up to 30 days. oem cpus can be rma'd up to 7 days i think.
check your cpu in another mainboard if possible (go to local computer shop maybe they will do it for you if you dont have another mainboard). dont put another cpu in that mainboard. if your cpu is dead, theres a decent chance that the mainboard was the cause.
its usually a good idea to buy the newegg warranty, especially when buying products made by dfi, leadtek, epox, ecs and a few others. also a good idea to buy retail cpus, unless of course, the oem version has been proved to be a better performer. then buy the newegg warranty.
good luck
i did buy a retail cpu, and i've got a refund RMA from newegg on both items, and the same items ordered 20mins ago with rush processing and next day air, so i should have them tomorrow hopefully.
thanks, the part that kills me about this is that the system WAS working, i got windows installed and then it quit for no reason, now i'm gonna be worrying that this new one is just gonna up and die for no reason
here's hoping it dosent nuke itself.
