voodoochildbc
- Jun 17, 2002
Hi,
Recently I had to move some rather large files (about 15 at 700 megabytes a piece) between two hard drives with identical speeds, interfaces, etc. The issue is that my computer seems to come to a halt when this takes place; I can't really do anything else. My setup is one HD on the primary master w/ a DVD Rom on slave, and another HD on the secondary master with a burner as the slave. Neither CD drive is under load during these file transfers. My primary drive holds Windows XP, programs etc., and my secondary drive is used mostly for data such as mp3s, (basically anything non-executable). Is this the proper setup for two hard drives to allow the fastest transfer speed possible? Or is my "lag" due to some other external factor?
Thank you for your responses in advance.
-Brian
-Brian
