Michael Scarn
- Aug 23, 2010
Workstation
i7-950 : Gigabyte GA-X58A-UD3R : G Skill 6x 4GB DDR3 RAM : eVGA 460 GTX : Corsair AX750 : 2x Samsung F3 1TB : 2x WD Black 640GB : 1x WD Blue 500GB : 1x Seagate 500GB : and the following storage setup:
Internal
640GB (Operating System). .[OS & Apps]
640GB (OS Backup). ............[OS Images and Backup]
1TB (Media Primary). ............[Media, downloads, storage, etc]
1TB (Media Backup).................[Exact copy of Media Primary]
500GB (Cache).........................[Strictly caches, temps, and pagefiles]
500GB (Export).........................[Temp export disk for renders, also hosts VMware disk image]
External
1TB (Movies).............................[TV shows, Movies, Video in general]
1TB (Master Backup)................[Comines Movies, Media Primary and OS Backup]
16GB (Flash Drive)...................[Most current projects and temporary file transfers]
Movies is currently in an external enclosure, accessed through eSATA
Master Backup is a hotswap, kept in a fireproof/waterproof safe when not being used
Other
DVDs.........................................[Movies, TV, and most things I cant recreate]
Media Primary
Apps (~30GB)............................[Games and apps I keep so I dont need to redownload]
Documents (~1GB)...................[Random printer scan, excel, word documents]
eBooks (~1GB)..........................[Various PDF books and such]
Editing Content (~20GB)............[Custom graphics and motion for projects]
Icons (~1GB)..............................[I like making Icons, makes folders easier to remember]
Music (~5GB).............................[Its music]
Pictures (~6GB).........................[Pictures that dont belong to projects]
Projects (~70GB).......................[All project files and accompanying assets]
Video (~280GB)..........................[Everything from my Movies drive, want to remove eventually]
Media Primary is the most important to me, and also will get the most access (and not just from my workstation computer). Currently, I only have my workstation as a computer. However, I am waiting for some power extension cables to finish my Pentium 4 case transplant to finish a FreeNAS build. Ill also be looking into a laptop to do some work away from home with.
FreeNAS
- Use for network backup of workstation and laptop
- FTP access
- Local network media server (nothing a 1TB-2TB hard drive cant handle)
Laptop
- I would like to get a dual hard drive setup, but only within reasonable cost. Hopefully setup as OS and Media drives. The Video folder will be absent from it.
- I want to sync the Projects folder, either from the Workstation or from the FreeNAS. That way I can have updated projects when I need to show clients on moments notice.
- Laptop will also be backupd to the FreeNAS as well.
I do small graphic design projects, bit of video touch-ups and rendering, and occasional computer maintenance locally. Things are fairly casual right now, with no intention of getting super busy until I have properly configured backups and proper synchronization between computers. I also figure getting some sort of offsite backup will be a must, either through peer to peer crashplan or using an online bakcup service. Even then, it will only require the Projects folder for the most part.
My workstation and NAS are behind a UPS. I dont get floods where Im at, few thunder storms. Theft is always an uncertainty wherever you live. I tend not to delete things, until I do a consolidation of my hard drive space (every few weeks). Regardless, I think snapshots would be important. I also like burning DVDs of finished projects, just so I can hand them off to someone else easy enough if ever needed.
The Projects and Documents folder are the folders that I would like redundancy for. Everything else, as far as I can see, are recreatable (time consuming in many cases). I stick away from RAID when necessary. With as many backups as I have, there really doesnt seem to be a need for them. I should also mention I turn off my Workstation when it is not in use or not rendering (or backing-up if that cant be done during its regular on time) The NAS would then be on 24/7 then.
I guess Ill stop there. My big questions then are:
- What software should I be running on my Workstation and Laptop for backing-up to the NAS?
- Can that same software sync my Laptop with my NAS or Workstation?
- For doing offsite backup, should I be using my NAS for that online service/crashplan?
- What methods do you guys use for some of the aspects I use my setup for?
Thanks very much you guys
Internal
External
Other
Media Primary
FreeNAS
- FTP access
Laptop
