Hello fellow Enthusiasts!
I purchased an Asus Striker Extreme, and when I set it up, it booted properly, but I smelled a slight burning smell, so I immediately shut it off. I inspected the board and could find no physical damage.
Since the board had seemed to boot properly, I decided to give it another go.
This time, I watched the board carefully, and just seconds after pressing the power button, what appeared to be a flash of flame
came from the power unit indicated by the yellow arrow.
You can see in this picture how the white text on top of the block is brown, unlike the rest of them.
My question to all of you is: Should I pursue getting this board replaced by ASUS, or was this somehow my fault?
I have since replaced the motherboard, and have been using the same CPU, power supply, etc that I used to test this board, so I can only assume this was a defective board...
Should ASUS replace this board, even though it is out of warrenty?
