extrafuzzyllama
- Jul 29, 2010
Hi all I have a 2 switches and wanted to now if i can daisy chain them but would I be able to use poe on the second switch by connecting it to the first switch?
My switches are HP procurve 1810g 8 port switch
It say they support poe but can't find info if i can power the second switch over poe by connecting to first switch poe port.
And when daisy chaining are there any settings I should change on the switches to work properly?
