So I am wiring my house with cat 6 and putting in some Ethernet ports in some of the rooms in my house. So here comes my dilemma: the internet starting point will be in the basement and the main switch will be here. Now I have to get some ethernet ports in our 2nd floor (2 floors above the basement). So I have fairly easy access to the attic from the basement by using a fireplace vent that was never hooked up to a fireplace, just has some foam stuffed it it to seal it. Is it worth it to have a few 150" runs of cable from the basement to the attic to have a direct connection or just to have 1 run to the attic with a second switch in the attic for shorter (a lot shorter, like 20 to 40 feet) cable runs?
Mostly it is just for internet access and light file sharing (we already have wireless but don't know what it is about my house, it is a black hole for any kind of wireless signal, cell phones any thing wireless just doesn't work that great here).
Also any recommendations on some good gigabit switches for this project (I have all the cable already)? I will be hooking these up to a monowall setup.
Thanks.
Thanks.
